how to set timing 72 merc 115
glazen82
hello i think the timing is off because it trys to back fire. i have put #1 piston tdc mark on fly wheel is on the marking that says max spark advance. but the rotor isn't pointing at the #1 on the dist. cap. is this right? please help. thank you glazen82.
Chris1956
Re: how to set timing 72 merc 115
Set the top piston to top dead center. The timing mark on the cowling support should match it, or the outer flywheel is installed incorrectly. When the carbs just start to open, the timing s/b 4* BTDC. Max timing should be 21*BTDC, with todays gasoline.
glazen82
chris 1956 thank you so much i set everthing to your spec and she fired right up. thanks again glazen82
