How to seal hole in carb?
dbocha01
had to drill a 1/16" hole in the bottom of my Rochester 2 Jet carb to free a stuck check ball. What is the best way to plug the hole?
jaxnjil
Re: How to seal hole in carb?
we use J B weld to seal the plugs on the bottom of Q-Jets
Bifflefan
some kind of gas proof epoxy should do the trick.
dan t.
use a small piece of lead,drive it into the hole,seal with j b weld
system-f
I did the same thing, used JB weld..no problems. I also called JB weld to make sure it is compatible with Ethenol gasoline and they said it is.
jaxnjil
never thought of that.
thanks for passing that along:)
i knew it worked with the OLD gas
