how to replace water pump on 1987 150 magnum 2
obpurdy
where do you disconnect the shift linkage? and how hard is it to do?
j_martin
Re: how to replace water pump on 1987 150 magnum 2
Not hard at all. I would recommend getting a factory service manual which has step by step instructions for your engine.
You have to drop the LU, of course. There's a nut in the front, two nuts over the cav plate, and 3 bolts from the bottom, one of which is under the electrode. It just drops off. Driveshaft is splined, water tube goes through a seal, and the shift shaft is splined.
hope it helps
John
obpurdy
thanks for the reply. it will help me get started while i wait for the service manual to arrive. matt.
lprizman
go on youtube, type in how to replace water pump on 150 merc and viola
obpurdy
thanks alot,that shows you everything i to do.
lprizman
have abuddie help you put it back in and align the shift rod and water tube properly
