How to replace trim reservoir? Mercruiser i/o
finlayj
My reservoir leaks all over the carpet every time I try to fill it up. Nearly positive the old plastic is cracked somewhere. Finally got a new reservoir but I can't find anywhere explaining the process of how to do this.
hoping its a simple disconnect and connect but you know...boats.
1991 5.7 350mag
thanks!
finlayj
Perfect! Thank you.
to refill I'm guessing put fluid in and run the trim up and down and add more fluid if necessary?
Ayuh,.... Welcome Aboard,..... You've got it right,....
