how to replace a rotted tilt rod for a Johnson 1990 hp?
ib18
how to replace a rotted tilt rod for a Johnson 1990 hp? what screw do i need to unscrew? do i hammer it? out?IMG_3112.jpg
raczekp1
Re: how to replace a rotted tilt rod for a Johnson 1990 hp?
hit the aluminum witch propane torch where bolts stack.aluminum should expand. whet gets expand apply some wd40 to float down in the rast
ib18
i was able to clean the tilt rod by pushing all the sands and rusts out of the tube, so will use it as is by cleaning the rust a bit
http://www.youtube.com/watch?v=1F6TKi396e4
Your local machine shop may have a drill / reamer to clean out the bore of the tube.
ib18
No Title
I did this using 1/2 steel bar from home depot, but my Johnson outboard 90hp is 5/8" and I mounted the motor onto board already, so now I have to remove it and clean it with 5/8" spade drill bit, or
ib18
No Title
i cleaned it with 1/2 steel bar but not enough for my steering cable of 5/8", so will have to lift my motor out of my boat to grind it with my 5/8" spade drill bit
ib18
ib18
ib18
ib18
