How to remove top from hull on 1969 V-163 to access transom?
derrhalt
Can anybody help me figure out to remove top half from hull. Have a 1969 v-163 and think transom is bad but it is difficult to access. Any suggestions.
Woodonglass
Re: How to remove top from hull on 1969 V-163 to access transom?
Post some pics so we can see how it's attached.
I THINK this is a picture of a Glastron V-163...
If so, then to remove the cap you just remove the rubber insert in the rubrail and then remove the hundreds of rivets or screws holding the rail onto the boat. This is the intersection between the Top cap and the hull of the boat. It may also have been glassed together at this seam and if so then a multitool is a good tool to use to cut it free. This is especially the case back by the transom under the splashwell.
