how to remove this deck
dmartin2190
Its probably been asked over and over and I'm sorry if it has new to these things but I'm trying to remove this back cap I guess u would call it to go have transom replaced I have everything unbolted from it but its loaded down with sealant and trying to get it to brake free wht would be the best way to do it the boats a 96 21cc astro bay boat I will get pic to post in the morning
Ayuh,..... Welcome Aboard,...... Hard to see much in yer pictures, but to answer yer question,.....
I'm guessin', it's gonna take some selective Cuttin' to get it apart,....
dmartin2190
thanks I dont bo of u can see any better in these pic but this deck isn't glassed in it was screwed and rivited in I toke everything out but it looks to me to be like silicone in I was wondering if it use a heat gun to try and soften that up will it mess up my fiberglass any
Woodonglass
you'll probably need to plunge cut a sawsall blade thru the glass to cut her free. Bass Boats ARE the most difficult transoms to gain access to. If the transom needs done, I'd highly recommend inspection of the stringers as well.
dmartin2190
ok that was last resort but its wht its looking like.. and ur right woodonglass from wht I can see inside of holes they look bad also its probably going a complete over haul kinda thinking that the boats not worth it but I do like the way it. rids and handles
Woodonglass
Yeah most Bass Boats of this vintage need a Gut Job but...she'll be better than NEW when you're done cuz your work WILL be better than the factory if you follow the advice you'll get here on the forum.
dmartin2190
thanks woodonglass for the info.. plus the wife loves it and been out with me the last 2 days stripping it
Woodonglass
Make SURE to use PPE when you start sanding cuz fiberglass dust is Nasty stuff TIP: Coat your arms and face with Baby Powder before doing sanding and you'll ITCH a whole lot less!!!
dmartin2190
I got another question I went to a local guy the does blessing and stuff on boats we cut a 4x4 spot to look at stringers and he was telling me for the last 2 years hes been doing ceramic in side of string by cutting off the top of the glass digging the board out cleaning it up and pouring the ceramic in side of the glass that's around the boards and reglassing the top of the ceramic have u seen this down hand how well is
kcassells
Way $$$ to do pour in and all good reviews. You can do it yourself too.
Ply will do just fine if properly installed.
Woodonglass
here's the deal. Composite material will ensure that you never have to deal with rot again but...Most people don't keep the same boat for LIFE. If you use wood and glass it the way it's supposed to be done. The wood stringers, Transom and deck will last for Decades and more than likely longer than you'll own the boat. The extra expense of composite material just doesn't make sense to me but...I am just and Old Dumb Okie!!!!:eek:
dmartin2190
will we not going with the pour in we going to coosa board everything and glass it in thanks for the response's
