Hi, I have johnson 120hp 1986 model, I try to take off the lower unit so I can change the water pump, I remove all the bolt but still stuck,only come down maybe 3cm , plz help
You Americans....sounds like shift rod to me......always thought a centimeter was a 1/2"....by the time Obama is done with you, you won't know the alphabet....
Undo the gear cable from the motor and then get in there with a flat blade screwdriver, the only benefit of having another person there is to watch them get frustrated instead.
First put some bolts back in to take the weight of the gearbox off the shift rod
