simpleinterest
- May 6, 2012
- 15
I have 14 foot sailboat with a large soft spot on the port side. We removed the inner skin and found that the 1/8 in coring was rotten, causing delamination. We have removed the coring and since the layer is so thin, we plan to do the whole repair using glass. We're almost ready to start laying glass, but need to remove the paint surrounding the cut, to promote adhesion. We plan to overlap the fiberglass.
As you can see from the photo, I've sanded down all of the high spots and the remaining paint is stuck in the weave of the fiberglass cloth.
How best to remove this paint? Options are:
1. Chemical Stripper.
2. Continue sanding through the fiberglass until all paint is removed.
3. Fiberglass over it.... hope that the fiberglass sticks to the paint.
4. ???????
4. ???????
