I am removing my gas tank in my bowrider due to strong fuems coming from under the deck. I wont feel comfortable unless I inspect it and change all fuel lines. My question is.........I would like to cut out a small area just big enough to remove the tank...and then use the same deck material to reinstall as it is in good shape. The tank is basically in a box between two stringers and two cross supports. My thoughts are to cut a hole very close to the edge of the surrounding stringers....and then for the reinstall, I would screw blocks, rails, supports whatever you call them to the stringers so the deck piece would have something to rest on and then screw the deck piece to the new supports.. will that work alright?.......Then I am not sure how I would fill the gaps between the decking that the saw blade left....marine caulk, 5200, fiberglass?????????? How do you guys do this?
Thanks
Thanks
