How to mount trolling motor on sea ray?
bshmjo
How should I mount a 50lb thrust trolling motor on a 21' sea ray? Are there any brackets / mounts designed for this boat? Any help would be appreciated.<br /><br />Thanks.
nmoxey
Re: How to mount trolling motor on sea ray?
I am thinking of doing the same thing. What did you end up doing to mount your trolling motor?
Wingedwheel
I made a bracket by taking a piece of wolmanized 2x6 and covered it with marine carpet. The you mount it to the boat with toggles. You can screw the trolling motor right down with lags and this leaves a minimum of holes in the fibreglass. I assume your talking about a bow-mount also.
ondarvr
A 50lbs thrust motor won't do much on a 21' boat, almost not worth the hassle or cost.
After looking I see this thread is 8 years old.
