gwgautney
Thread starter- Joined
- Aug 28, 2013
- 283
I have a 1998 ocean pro 175. I got the boat and there is no tach on it. I know this motor has system check on it but all the plugs have been cut off of the wiring harness. What I'm wanting to do for now is hardwire a tack in so at least I can get my rpm's to get the proper prop on it. I am planning on replacing wiring harness and getting all of that straightened out at a later date. Anyone know what I need to do. I know one wire goes to the ignition but I have no idea which post to hook it to and what would be the sending wire color. is there a ground on the ignition or does it need to run to fuse block. And last what setting does the tack need to be on I see several on the back. the tack I have the needle is not sitting on 0 its at about 4 can that be fixed with the calibration setting,
