billybob1970
- May 10, 2012
- 2
so I have a 1967 mercury 65hp outboard. When I bought it we had it running and it ran great but would not idle that well. I took it to a marine repair shop where they told me they would check it out and let me know if it was worth repairing. They checked the compression and said it was good between 115lbs and 120lbs. They then checked the spark and said that it was excellent. They started the motor up and said it ran good but needed the carbs re built. I am into this for approx 560 dollars. 2 weeks down the road they call and tell me the motor no longer runs and that my ignition timing is screwed and that I need a new distibutor assembly which is virtually impossible to find. My question is that I took a functioning outboard into them to be serviced and now i have a motor that does not function at all, should I fight to have them give me a replacement motor?? I have been told by other marine mechanics that it did not sound right that it ran nice when they got it other than struggling to idle which they confirmed to be the carbs and now does not run at all.
