How to get to Impeller(water pump) 10 HP
thebigfish1
Serial # B100S-1500011 Honda
I took lower unit off, there is no impeller. There is a rubber hose (short piece) the leads into upper unit. Do I have to remove the engine from the Base? & If so what are the steps, I see 4 bolts on outside of case, What about the bolts around the drive shafe ,looking into upper housing ? Any help on getting to impeller would be great ...Thanks
