Folks, I'm wondering if you could assist on this:<br /><br />I have a 10' Zodiac--soft bottom. It's seen a few years, but it is a pretty good tender. Powered with a 5 HP Nissan, it is actually much fun.<br /><br />Problem is: I have a nagging problem with the floor separating from the tubes. I've glued this a few times, but the leaks continue.<br /><br />I'm tempted to remove the floor from the tubes, and re-adhere.<br /><br />Any suggestions for how to do this? (Should I not remove the floor? How to seal this?)<br /><br />I did hear there is a technique using a heat iron. True?
