how to fish
j_martin
Re: how to fish
If you want to catch bass without having to learn to cross their eyes with the hook set and dodge the bait if you miss, do this.
With any rig that is medium weight or heavier, and 12 lb or better line, put on a #4 plain hook (large crappie size) and get some heavy salted worms, like Senko (costly) or a ripoff. 5 inch or 6 inch will produce the most bites. I make my own. If you get a green (motor oil is best, maybe watermellon second best) black, and purple, you'll cover most of the taste preferences of bass. Hook the worm once in the middle, and throw it where the fish are, and let it sink on a slack line. If you see the line move, gently feel for a fish, and set the hook if you feel one.
Another real good worm for this is a 6 inch zipper worm. If it's not salted, you have to add a small split shot or 2 close to the hook to get it to drop at a natural rate. The common factor is that all these baits are soft and wiggly.
A little Kick-N-Bass crawfish scent makes em hold on till you figure out you should set the hook.
If you want to get serious, get a decent cheap level wind (Abu Garcia Black Max is OK) put it on a medium heavy 6' to 6'6" graphite rod (need not spend over 25 bucks) and load the spool 1/2 full of 12 lb mono, then top it off with 75 yards (1/2 spool) of 20 lb spiderwire braid. (tie them together with a blood knot) Spiderwire 20 is the diameter and limpness of 6 lb. mono. You can throw your bait half way across the lake, and when you're fighting fish, you don't have to worry about horsing it because your line can take it.
I've been bass fishing for 20 years. I finally talked my wife into getting out of bed and going with me. Set her up like this. She cleaned my clock for 3 hours.
My son and I had an outing on a local lake that is an average bass lake one friday morning. We both used the wacky worm rig I described above. In 4 hours we put together a 35 lb stringer of bass.
Shizzy
Ensign
Re: how to fish
You do not need to spend a weeks pay on a fishing reel and pole. a simple Zebco 33 will do like $30 at most any Kmart or Wallmart..
I used a $12 baitshop spinning combo for years with no problems. In fact I just tossed out the old girl this year (lasted 20 years)
gonefishie
Re: how to fish
STOP Do not go to bass pro and spend a week there.Search the web since you have a computer. You do not need to spend a weeks pay on a fishing reel and pole. a simple Zebco 33 will do like $30 at most any Kmart or Wallmart.. Get yourself online look for fishing technics video many many sites have them for free your hook set is a Major issue from ready point to end of sweep is on 1 foot the tip of the pole will move 6-8 feet also that allows for mono stretch. buy your self some 3 1/2 tube baits with these weights in hooks wide gape 1/4oz 1/2oz 3/4 oz I hold the Michigan state record for small mouth bass so I know what I am talking about also change the line on the zebco setup go with Berkly Big Game 8- 12 lb test tops also get a water chart of your Lake and fish point breaks and drops also the weed edges Have a Good 1 TnTPoof tear apart your reel and lube it with a Good reel lube after you clean it with some carb cleaner on a tooth brush.. then lube that reel wipe off all excess lube mono dont like oil on it eats it up..
I think you might be the new record holder of the iboat's longest paragraph without any comma and period.
coolguy147
Re: how to fish
if he gots that then i got the iboats worst grammer spelling and sentence structer
gonefishie
Re: how to fish
There was a member who didn't stays around for very long. I think gatored96 was his name. Does anyone remember that guy? He got you beat coolguy.
coolguy147
Re: how to fish
url]http://forums.iboats.com/showthread.php?t=274791&highlight=1959+10hp[/url]
my very first post. most people didnt talk to me after:eek:
can we get back to fishing
i tried to get out today but i dont get any hits!! i dont get it
Shizzy
Ensign
Re: how to fish
this is the EXACT reason I was mentioning keeping a journal. you can write down all this info about what did NOT work this time of year with this weather.
pontoonokie
Re: how to fish
ok.. i didn't read all the suggestions so if this came up i'm sorry.. but you must go and get you some sharp hooks .. also be mindful of the turn of the shank.. some with the offset eye get a better hook set with a straight vertical hook set.. not the side to side set... also i did see some suggestion lines.. there are line with more stretch.. these are no good for worms.. you need a good connection between you and fish.. also a little slower tipped rod.. aka stiffer rod.. just my .02
curtis
