how to find correct prop/pitch?????
BeerMonkey
i cant seem to find a giude to find what prop i need to a 89 20" sun tracker pontoon boat with a 89 40 hp evinrude. i think i have a spun hub and one of the blades is a bit bent. any help on finding hte right replacement would be great.
BeerMonkey
Re: how to find correct prop/pitch?????
also how do i find if i need a standard rotation or reverse or both????sorry if thses are stupid questions ive only had my boat for a week
jevery
You need to start by removing your prop and looking for size (diameter), pitch, or a manufacturer and part number stamped somewhere inside the barrel. Prop could likely be re-hubbed and blade repaired by a good prop shop for considerably less than replacement cost or you could replace with a comparable aluminum prop for not too much once you know what to look for. You'll need a standard rotation prop, reverse rotation is only for one of a pair of twin engine setups.
Silvertip
Honorary Supreme Mariner
Without a starting point, one can only guess at what you need so that starting point is the prop you have now. Look for numbers such as 12-1/4 x 13 (12-1/4 inches in diameter and 13 inches of pitch). I'm guessing, but I feel thats what you currently have and will be close to what you need.
BeerMonkey
ok i took the porp to the local boat place and they found what the model was a found it was a 17 pitch he said i should be useing around a 13 so thats what i got, seems to be better but the motor is not running top notch right now anyway
