How to disconnect oil injection
willyp
Anybody know a quality dealer that has powerheads in stock for exchange?I have a mercury 1995 30hp 2-cycle ser# 0G084415.Also what mods do i make to disable the oil injection system? block,plug,cap?<br />I plan on running premix from now on.Thanks for any input.<br />Willy <br />Ph:1-800-400-9678
Drybo
Re: How to disconnect oil injection
Not 100 % sure but to try to help you need a kit that allows you to plug the oil pump drive gear after it is removed. Click search above and type your question, many posts deal with the oil pump, <br /><br />Don't know about the powerheads but iboats motors<br />offer them. Click motors above.
willyp
Originally posted by byrdog:<br /> Not 100 % sure but to try to help you need a kit that allows you to plug the oil pump drive gear after it is removed. Click search above and type your question, many posts deal with the oil pump, <br /><br />Don't know about the powerheads but iboats motors<br />offer them. Click motors above.
willyp
iboats does not carry this unit,anybody else know? thanks for your input<br />willy.
willyp
Anybody know a quality dealer that has powerheads in stock for exchange?iboats does not,I have a mercury 1995 30hp 2-cycle ser# 0G084415.Also what mods do i make to disable the oil injection system? block,plug,cap?<br />I plan on running premix from now on.Thanks for any input.<br />Willy <br />Ph:1-800-400-9678
