How to disable 350MAG ignition coil?
saaristo
I’m planning to use fogging oil for winterizing my 2005 350MAG engine, simply by spraying it through the spark plug holes into cylinders. In order to not dilute the oil while cranking I need to disable the fuel pump and ignition coil. Fuel pump I know what to do, but can somebody help me figure out which connector to pull from the ignition module? Is it the one up left or the one bottom right?
Fun Times
Lanyard safety kill switch at the helm should kill both the circuits in question and still allow engine to crank over…
alldodge
I’ve done the fogging with oil/gas mixture before, though on Pentas. But just to educate myself, why not do the direct fogging with MAG350 MPI?
There are sensor inside the intake MAP, Temp, and others depending on model. The fogging oil will coat the sensors and cause them to measure incorrectly and or fail
And a catalyst motor could even worst
