Rotorpilot1969
- Sep 8, 2012
- 35
I have a B-2 with a B3 dual,prop foot, I bought this drive used and it works great but I've had other boat issues with low rpms and starting to think the ratio on my outdrive is wrong for my boat. I need and thought I purchased a 2.20 ratio as stated on the side case but seeing this drive has been turned in to a B-3 I'm wondering if the gears have been changed. I removed the top upper cover and can't see so well but think I counted 32 teeth but was wondering what is considered the drive gear? The gear I counted 32 teeth on I believe is the driven gear. This could still leave me with a few other choices depending on what the drive gear is. Where is the drive gear and is it viewable without removing the drive.
