How to Core sample stringers.
Yacht Dr.
Hello All.
I would like to share some experience and some inexperience on how to core sample..
1. If you need or want to drill out fiberglass to get to the core to see what comes out then make sure you can reach that hole to grind and glass it back up...
2. You Will Need to put a few layers of Mat over it to seal after your exploritory. Using just PB, filler, Whatever in the holes will not seal your hole.
Its that simple...Fillers will Shrink..and fail leading to possible water intrution.
YD
