How to connect 2-wire tachometer
BMundell
Hey iboats community,
I'm trying to hook up a 2-wire tachometer that's been in my boat (1975 Glastron 187-Swinger, Volvo 280 outdrive, Ford 302 motor) but was never hooked up. Actually this would be the third of three tachs, both 2-wire and all with essentially the same wires and adjustment switches/screws.
The current tach is a Aqua Meter, the other two were identical and I believe the original Teleflex tachs. Both only have a black wire and a gray wire (assuming sense/signal). I've tried connecting the gray wire coming from the negative pole on the coil to the gray wire (I confirmed this wire had continuity to the connection point), and the black wire to ground as well as to switched power, but neither option gave me any readings. I've also tried changing the bucket switch to all available positions to see if the tach was not adjusted correctly for an 8-cylinder engine. However, there are no lables on any of the tachs at this point to indicate which setting it's even on.
I assumed this would be an easy hook up, and I originally thought that I probably had a bad tachometer. But now that I've tried three tachs and failed three times, I'm obviously missing something. I've attached pics of the Aqua Meter.
Thanks for any info!
Ben
