Re: How to check gages!
seabob4 said:
Excuse me, but I've been building boats for 15 years
So for 15 years you haven't learned not to use wingnuts on a battery, and not to use a deep cycle as a starting battery yet???
How many starters and stators do you go through in a year?
Wouldn't hurt to put a fuse or a circuit breaker on that house power wire either.... coz nuthin says lovin like a 30 foot fuseable link.
Just sayin........
On to the gauges. Gauges are easy. They typically have 2 circuits.
1 is 12v in with ground for the lighting if the gauges are lit.
that takes care of the first circuit, doesn't matter if the lights work or not, identify it so you don't get confused.
The other is the gauges circuit itself. It's 12V in, ground, Input and/or output.
Verify that you have a 12VDC and a good path back to battery ground with little resistance.
After that, if its an output type gauge, like say a fuel level gauge, check for 5VDC on the output wire. If you have 12V to the gauge, and a good ground, and do not have 5VDC out then you have a bad gauge. If you do have 5VDC out then take that wire and touch it to ground. The gauge should go to full, if it does not the gauge is bad.
With an input type gauge, such as a tach. Check for power and ground. touch the input wire to ground and the needle should peg to the right, or max rpms in case of tach. if it does not then the gauge is bad.
