How to change from Left hand prop to Right hand Prop
stubbylong
1984 Volvo Penta AQ125A 270 currently is set up for Left Hand prop but has a right and prop on it. How easy is it to just change it so I can use the right hand prop?
Maclin
The shift cable out on the drive can be moved to the other end of the arm that pivots in the drive. This is from memory, but there is a cover out on the back side of the drive, just one or 2 screws, it is meant to come off. You should be able to see what I am trying to reference. Volvo drives run the same in either direction, one of their good features.
PatinIdaho
Remember to change the trim tab setting also from right to left also.
stubbylong
I was able to replace the arm on the back of the drive to the other side. But I don't know what or how to do the trim tab setting??
PatinIdaho
No Title
See the part circled in red. It swivels after loosening a bolt on top. Move it so it is pointing about the same amount off center the other direction.
