How to bleed/fill tilt trim
Larry petersen
Can't figure out how to first off fill up tilt trim on 1990 reinell, replaced electric motor, motor work but will not lower_raise prop. How do you fill and bleed
Larry petersen
Put atf in, an once I lowered unit it blew out o ring, I replaced it on the reservoir side, Now I can't get no response other then motor is working, anyone direct me ing the right area
