How to adjust lean/rich knob after carb rebuild
Fishermanwill32
First off my motor was having idle problems the last time i took it out. Today I rebuilt the carb. I messed with the rich/lean knob before firing it up and when I first cranked it with the choke out it revved higher than I have ever seen it. It was for sure the highest rpms I have seen that motor put out. I immediately shut it off. Due to sunset I had to stop there for the night. Do you think the engine is running to rich?
jimmbo
Too rich doesn't make an engine rev high. Too high of a throttle setting will. When you reinstalled the carb, did you check/adjust the synchronization of the carb to the ignition advance? As for adjusting the mixture, turn the needle in until it GENTLY seats, then back it out 1 1/2 turns. That is a starting point, then with the engine in gear at a slightly higher than normal idle speed, adjust the needle for highest speed. Lower the speed to idle and readjust for best idle
