Re: How soon can I wash and paint? Unwaxed poly resin
Looks like a "fold/crease" in the glass ..
White should not happen when rinsing off..
Could be old wet folded glass..or just a case of not using mat with the 1708/roving ..
Surface white again..should not happen. Did you put any wax or other additives in your Lam resin ? ..
YD.
The only time I added anything was to make filler(PB). when I was laying down the glass it was straight resin with 1.5% mix.
the board you see on the side, that was initially covered in 1.5oz csm , i filled the gap from the board to the hull with Pb. Came back day after sanded, wiped down with acetone then layed down the strip of 1708.
The top side of the mount got a layer of 1708 then the roven...should I have had a layer of csm in between the 1708 and the roven???
The best way I can describe it , it reminds me of the kids toys that change color when water is on it.
spent the day in the sun and it looks better
