How often do you use fuel stabilizer?
mickjetblue
I'm not looking to promote any particular brand of product, but I just
wondered how often everyone uses some fuel stabilizer or conditioner
in their fuel. I see many posts about slow idling and carburator problems,
and I have found that both of those have not been problems at all for me
since I started using fuel stabilizer consistently.
I put a couple of ounces into each tank, and that seems to do the trick.
I think it is a preventive maintenance measure, keeping the fuel system
cleaned all the time, rather than letting crud build up, and then having to
treat a problem.
bhammer
Ensign
Re: How often do you use fuel stabilizer?
I use one all the time, and it it formulated to help deal with the ethonal fuels. It is high strength and has a built in measure for each load of gas. I think it is up to 20 gal per ounce.
frankie g
I use Tron, everytime I ad gas... 1 oz. per 16 gals. never miss adding it!
bjcsc
I use it when I winterize and use nothing else all the rest of the time...I also use premium gasoline...
Silvertip
Honorary Supreme Mariner
SeaFoam for me in every tank during the season and Stabil during winter storage.
Boatist
I have never use it at all and never had a problem. Boat one year was not used for 8 months and I figured would be a big problem so made sure the kicker had fresh gas but when we went out could not tell the difference.
a70eliminator
Well that makes me feel alot better, I fueled up mid april 40gal and I've been out only once since that still have 3/4 tank of 2month old gas and may not get back out for a few weeks yet. I'm not using additives, but as someone said already fuel of today isn't what it used to be, so I'm told.
Dakota47
during winter only.:D
dingbat
I only use it during my 2 month winter layover. I have a 92 gallon tank and try to keep it at least half full at all times to minimize condensation. I also refuel after every outing to keep fresh gas in the mix.
Addative wise I don't use anything. I've been using e-10 for 3 years now and its cleaned my system out to the point that everything looks like new from the tank to the carbs bowls. The Racor takes care of any water that my have infiltrated the system. Lifes good :)
Silvertip
If you have carbed two stroke power, carbon guard, SeaFoam or any of the other additives are highly recommended to keep carbon build-up to a minimum. SeaFoam is a great product for a high-dose decarb process.
Maclin
I use Sta-Bil each time I put gas in (V8 sterndrive, 87 octane). It does not seem to affect performance at all, and realistically I never know how long it will be until I get back out in it. Also that way it is always all the way thru the fuel system so if I do need to do a quick layup I do not have to worry about getting treated fuel all the way into the carb. I just leave it thru the winter with whatever gas there is left after the last trip.
ziggy
stabil at the end of the season for winter layup... after sumerization. premium fuel + keep fuel tank topped off on the high side
NSBCraig
I use Stabil every time I .....um have some.
Gary H NC
Stabil for winter storage and about 3 cans of Seafoam over the summer..:)
KETELS
There was a article in one of the boat magazines about this.
It saied if you don't use your boat every weekend you should use some form of stabilizer all the time. I use Stabilizer all the time.
eli_lilly
I used nothing until two weeks ago when I had 12 gallons of E10 phase separate after two weeks in the Florida humidity. It's the first fuel problem I've had in 3 years and the outboard would not run at all on that tank. Now I use Star Tron on every fill.
-E
