How much power?
Princ40
I have a 1976 starcraft ss supersport 16ft. I bought it last summer for $1500. I ran it last summer on a 1974 Johnson 70hp. The motor had issues when I bought it. Now when I took it in to have it looked at the guy wrote on my reciept "Not Worth Fixing". Low compression in the cylinders and the lower unit was replaced with a newer year so the throttle is backwards.
Here is my question.... What is the lowest hp motor I could go with? I am only using it for fishing on inland Michigan lakes.
I don't have a ton of money to sink into a motor.
I think this question qualifies as a non-repair discussion??
ezmobee
Re: How much power?
Well darn near anything will push a 16' aluminum Starcraft. However I don't think you'll be real happy with anything less than a 50. If your 70 was a '78 or newer I'd probably go with a rebuilt powerhead but being a '74 I'd part it out.
Re: How much power?
So how did the boat perform with the "tired" engine? A properly running 75 HP two stroke will very likely work ok if you were even somewhat satisfied before. Generally however, 70 - 75 HP should be fine on that boat. I can assure you dropping back to a good running 50 HP motor will likely perform about the same as a tired 70. If there is a maximum HP tag on the boat, then the rule of thumb for acceptable performance is 70 - 75% of the maximum rated HP. If the boat is rated for a 90 HP max then 65 - 75 HP would provide acceptable performance.
hidef
Re: How much power?
Depends on a number of factors how much does the boat weigh, how fast do you want to go and how much do you want to spend. I would think that a 50 or 55 would pretty good choice. I wouldn't want to go smaller than a 40 horse and whatever you buy should bolt on to the transom because of the holes that are there from the 70.
Home Cookin'
Re: How much power?
assuming it's aluminum--we had 2 growing up with 55's and they were fine for all use. Regardless of your limited use, you want to be able to get on a plane, so (guessing) not less than 35.
A guy near me has a 9.9 on an old 16' bow rider. the boat is a wreck. But he only uses it to dinghy out to a moored sailboat. Great idea, though: a free boat with lots of room for gear and a cheap motor, instead of an expensive inflatable or skiff.
Princ40
Re: How much power?
Went with a 1992 mercury classic 40hp. Pick it up Friday.
Chinewalker
Re: How much power?
I had a 1977 16SS about 20 years ago. Before I picked up my Johnson 75 for it, I ran the only long shaft motor I had - a 1957 Evinrude Lark 35. It actually performed quite well - even with a couple people onboard, it would plane off easily and probably did 25 mph or so.
Your newer 40 Merc should do quite well. Prop it accordingly...
Bamaman1
Re: How much power?
I'd be looking for a good used 50-75 hp two stroke motor. With BoatTrader.com and Craigslist.com, they're relatively easy to find.
