refractory148
Thread starter- Joined
- Dec 20, 2003
- 50
I have a 1998 25HP Johnson Model# J25RECB. I drained the lower unit and would like to know the proper amount of lube to add to refill it properly and what type lube to use. I picked up a quart of "Pennzoil High Viscosity Lower Unit Gear Lube, SAE80W-90, API GL-5 Performance". I noticed there was also a lot of oil that was rated TCW-3 i think it was so im not sure if I have the right one. Also this is a hand controlled motor and on the hand control there is a knob. It is on the very end of the control arm by the throttle. It turns but im not sure what it does or if it even does anything at all. I first thought it maybe an idle adjustment or fuel:air adjustment but it doesnt seem to do anything when turned. Guess I need to go get a manual for this motor.
