FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
It should pulse rather strongly. Squirt a couple of inches, not dribble. Enough that you would want the hose end in a container. If I remember correctly, the numbers quoted are 2psi at cranking up to 6 psi at running.
This assumes that the primer bulb was used to fill the fuel line and carb before removing the hose and cranking the engine. The fuel pump will NOT deliver enough fuel to self prime by cranking the engine.
This is my first time to rebuild a fuel pump and I don't have a manual. Does the gasket go oh the lower or upper side of the diaphragm? I am considering the lower side of the pump to be the part with the sediment bowl.
Thanks
