how much does my leg weigh
Timothybre
I have an older Volvo Penta 280 leg and I need to change the billows. So mw question is how much dose the stern drive (leg) weigh. Can me and my buddy just use our muscles to remove and reinstall the leg?
Ayuh,..... 'round about 100 lbs. or slightly less,....
you can do it yourself.
put a piece of 1/4" plywood between the driveway and the skeg. lower the drive, remove the pins, remove the helmet pin and rotate the helmet up, remove the shift cable pin and retention plate, pull the 2 bellows clamps and the hose clamp, then pull the drive up and back.
Timothybre
I'm sorry but some of what you were saying I done understand. So I need to buy a or build a frame so the leg wont fall over when its not attached to the boat?
Tail_Gunner
5 yrs ago I would have said...it's clumsy but quite manageable. 4 yrs ago I popped a hernia on a RV tire of all things.
Bravado has left the building so to speak.
no one said anything about a frame
and yes, if not attached to the boat, you will need to hold it in the upright position, or bear hug it and set it on the tailgate of your truck or your work bench.
if you want to build a stand to hold the drive up. then do so. scrap lumber and an $8 dolly from harbor freight works well.
This is from the last few pages of the thread in my sig
0122221816-jpg.355021
Timothybre
thank you so much for all your help I'm a little new to inboards and I am great full for the help.
