how many volts shouls i have ?
stevetheplumb
on testing my charge system today, i was wondering if my rectifier was blown?
my battery has a resting voltage of 12.40 volts
whilst running at tick over approx 1000 revs volts go to 12.47 volts
when at high revs volts go to 12.67 volts
i always thought revs should be around 13-14 volts
ive tested stator and looks like its creating plenty around 16v
any thoughts?
stevetheplumb
Re: how many volts shouls i have ?
thanks interesting films didnt realise i could use different rectifiers
pnwboat
Yes, a standard full wave bridge rectifier will work. Highest current output stator that was used on the Force engines was the Mercury style which was rated at 16 amps (12 pole). The 16 amp stators used a rectifier/regulator. The older stators (20 pole) were rated at about 9 amps and typically just used a straight bridge rectifier. There is a "sticky" at the top of this forum titled "If you have high charge voltage" that has some good information.
jason32038
When you tested at "high revs" was it the fast idle position (about 2000 rpm) or full throttle (5500 rpm)?
