Re: Labor estimate to assemble 1994 Cobra SX drive
Boatguya1, I can appreciate your questions.
Original problem was bent prop shaft and leaking prop shaft seal. Believe it or not, but a 5 minute run time with a bent stainless steel prop bent the shaft. On the lift with the aluminum prop-no leaks. Went to pull some tubes and changed prop to my SS "pulling" prop out on the water. Prop had been dropped and was bent but I didnt realize what a mistake to put it on was until I ran it. Ran it back into a calm cove and replaced with the aluminum prop. Back on the lift, and noticed leaking oil at the prop shaft seal.
They were to separate upper and lower halves, repair lower half, check rolling torque, reassemble and leak check. Mechanic misunderstood and disassembled upper half too. When I showed up and said WTF?, became a "he said, she said", and had a falling out with the shop.
I just want the upper assembled, plain and simple. Dont confuse this with "I want my drive overhauled". All the parts are there but, no, I am not certain they are mine but have no reason to believe they are not. Still have the shims. Im not interested in asking for a warranty as this is a piecemeal job, but I expect the lash and shimming to be done to spec. Dont want the shift cover installed as I will check the gear tooth pattern with marking compound. After checking, I will install the shift cover, shim it, and put the upper half on the shelf as a spare, should I ever need it.
All I really want to know is how many hours does it take an experienced SX drive guy to do the job as I have described. Forget what I said about parts in my original post. When I start shopping to get the job done, then I am armed with what I believe would be an honest estimate of the labor hours.
What was the failure to begin with? What was the mistake they made? Do you just want the upper assembled or do you want the drive assembled and installed filled with oil and tested? Are you certain that the box of parts is all from your drive and all there? Are the old shims available for a starting point? Am I responsible to warranty the unit full of used parts? Are some of the questions I'd ask prior to giving an estimate for a job like this.
