How many amps? 1980 75HP
skycam_tx
How many amps would a starter draw on my outboard when cranking it up? :confused: <br /><br />I ask because I want to get a battery switch. There are 2 models...1 is 200 amp max and the other is 500 amp max. Obviously the 500 amp is more expensive(twice as much). Is there a way to test this? <br /><br />Also is it better to switch the + or the - lead. I was going to switch the - lead.
force01
Re: How many amps? 1980 75HP
Most chrysler starters draw about 170amps, but as they get weaker or burn up they can draw 400amps. that is the point where you might need a heavier duty battery switch. bret<br /><br /> If you need further assistance please email me @ forcepower01@yahoo.com. thanks,Bret
