bkwapisz
Thread starter- Joined
- Oct 20, 2009
- 441
I tried this post in another section and got no joy, so I'm trying it here:
My 1990 GT100 does not indicate a good charging votage across any number of meters/gauges until it's been running for at least 10-15 minutes, then it cycles between 12 and 13.5V, mostly at 13.5. If I shut it off, the cycle starts again. According to the manual it should start immediately. Is this correct? Anyone have thoughts as to why there is a delay? I'm going to run the diagnostic checks this weekend on the regulator and the stator, but wondered if anyone has ever heard of anything like this issue. Doesn't make much sens to me. I did check the wiring and grounds but I suppose I should check again. I did read on here that thumbscrews are a no-no on the charging posts and that's what I have, so I'll replace those first. And all of the contacts look virtually brand new. Also, the previous owner has a deep cycle battery as the starting battery, which I also thought I read was a no-no. At this time I have no problems with anything on the boat, but I'm a habitual gauge watcher...:redface:
Thanks for any advice here.
