How long at WOT?
QC
Re: How long at WOT?
Merc used to say forever, in print. They also mentioned shortened engine life . . . So there it is.
haulnazz15
I can tell you that piston airplane engines are not rated to run at continuous WOT. They aren't designed that much differently than automotive engines.
Convince a renter of a 172 about that, lol. 2450rpms is still less than 2500 redline. :)
Philster
Yes, if its a closed loop fuel injection system. Otherwise, fuel is delivered as a function of the amount of air.
Accordingly, you must claim a 2-stroke engine can never experience a running lean condition???
Philster
You and I are in agreement, Frank. Load is the variable, but valve float doesn't care . . . :)
I have no idea what my point is other than most of this stuff is speculation. The impact of load on engine life is variable, the impact of RPM is variable, so what do we have to base any of our positions on? Nuttin' . . . :)
Sooo... what?? Let's not have a healthy discussion to flesh out some conclusions?? :p Am I the only one comfortable with this thread, even if it's not 100% based on statistically valid studies?
QC
Just a reminder, and this is factual. Otto cycle (4 cycle, throttled, with spark plugs) engines' efficiency is best at WOT for any specific RPM. A little at odds with some positions here ;)
QC
I love this thread. I have an issue with some of the speculation. Ultimately without data we are debating opinions. Always frustrating. Doesn't mean we can't keep frustrating each other. That's what we do best, Phil . . . :p
QC
Both closed loop and "open" engines determine fuel delivery based on air . . .
bruceb58
True. I was always conservative when I flew so I always followed the guidlines my instructors taught me.
QC
QC, Phil and Bruce should not be allowed to post before counting to 5700 cc's.
bruceb58
Agreed. I was saying that a closed loop system can make changes based other than just air.
Philster
Well, you'd win hands down, QC. :p
There are some intelligent conclusions you can make. I am not so sure of running at WOT as an issue at all, because it's usually lower than the kablooey point (where an engine might go kablooey).
If the fuel/air and timing hang in there, and the engine's oil and overall cooling system are making out fine, then there is more load, but we'll need a metallurgist to tell us how the metals get softer and more prone to wear when under more load/stress... or not. :)
Philster
Well, only if it doesn't have to push an object through air. Or are we going to hear some distinction between efficiency and economy (MPG, etc)?
QC
Aerodynamics have nothing to do with that statement. I didn't say Marine application or Automotive. The real world gets in the way of all of this stuff, but . . . Otto cycle engines are most efficient at WOT. Not WOT RPM as we use it, WOT.
Here's a clue for you, diesels are always at "WOT" . . . cause they ain't got no stinkin' throttle.
Philster
I'm applying everything to engines in vehicles here and how they are used by people.
Philster
It's also 2012 and throttles are now being incorporated to control emissions. :)
QC
OK then if the vehicle is a boat, assuming a planing hull and efficiency is the goal, then just onto an efficient plane is the best, no matter what the RPM is.
In a wheeled vehicle it is 58 - 62 MPH and smallest engine, highest gear = most wide open throttle.
