How large an outboard for emergency tow
iflyboeing
I have a small (34 foot / 8000lb) single engine houseboat on inland waterways. I would like to outfit her with an inflatable to use in the event the single engine fails. The inflatable would be in the 10' range. What is the horsepower needed to tow this houseboat at least out of the way of the channel.....and possibly several miles?
rockyrude
Re: How large an outboard for emergency tow
I doubt you'll be able to put anything bigger than a ten on that inflatable, if you don't have to fight strong currents it'll pull the houseboat. Just not real fast and you're not supposed to tow fast anyhow.
Fireman431
Using an 8-10' inflatable, you could probably get the thing moving with a 9.9, but it's going to work it. A 15 would work better, but then you'll need to step up to a 10-12' boat.
Now, the more important issue. Once you get it moving, how are you going to steer and stop it? You can't hip tow it...too big. If you have someone steering for you, once any wind or current catches the houseboat, the inflatable doesn't have enough bottom to grip the water and counteract the outside forces. Now you've gone and let the houseboat and the inflatable drift into problem areas.
You might be better with a rigid hulled inflatable. But to get the grab you want, you need weight. Look into 14-16' with a 50 hp to move it safely.
Wouldn't it be better (in my opinion) to invest in a 25-40 HP kicker engine mounted on the transom for emergencies?
Stachi
why don't you just mount a 25 hp kicker on your house boat...unless you are looking to justify an inflatable... :D
