How is this prop?
ob15
I was looking on eBay and noticed this prop. I was just curiuos how this prop would be on my motor. It's a cleaver so I'm not sure hat that would do for me. They are surface piercing props, right?<br /><br />I currently have a SSII 11 1/2 x 19 and the wot rpm is 5800.<br /><br />15' hombuilt skiff (fairly light)<br />1989 Johnson 50 J50TLCEC<br /><br />Thanks again!
walleyehed
Re: How is this prop?
From my experience with true clevers, you have to spin them fast, and not much more than half of the prop is in the water. They seem to be fast, but they lack in bow lift, and are ONLY fast if you can run'em on the surface on the right kind of hull.
ob15
Thanks for the info Kenny. I didn't think it would fit my application but was curious.<br /><br />BTW, a while ago you mentioned you we testing some new props? Just wondering how that was going?
walleyehed
If I can get everything Data-wise put together, I should have everything in the next couple of days...
ob15
Looking forwward to that. Thanks again.
walleyehed
Yea, I got in a bit over my head on this one...<br />I found out "Real" quick that if I am going to test "New" props from 1 manufacturer, they've all got to be new to be fair...Talked with several manufacturers and all have been great to work with. When I complete the documents, The manufacturers get the results first, then if nobody has any problems, they will then be released on iboats via Bruno's OK.<br />I hope to be allowed a special post on the prop forum to list these in order...we'll see.
ob15
We hope also.<br /><br />Please Bruno! :D
walleyehed
I got an email this PM from Bruno...he says "we're looking fwd to the results", so, I'll be posting them as soon as I get all the numbers together and the manufacturers say "OK".
Ron G
I can barely wait to see some of the numbers too.
