Re: How important is that fin??
Some of you will think I'm nuts but I don't really care because I know the correct answer and believe it or not it's a good thing that you don't.
I've had a lower skeg on a go fast motor let go on me at 80mph. I ended up in the hospital and the boat was never recovered. Now you might argue that this is not a go fast boat but I will argue back that a hard left turn at 35 mph will throw passengers out and can cause the boat to flip.
They are just cast aluminum and the quailty to begin with is poor. If you've drug it and bounced it up a ramp or smacked it into a rock it needs to be checked thouroughly.
The bolt on replacement skegs are probably the better option for repair since they bolt through in an area that usually doesn't get damaged. Only an inexeperienced boat shop would offer to weld a new one on for you. Do not go that route. If you're in doubt, replace the entire casing. It can be a lot less expensive and will give you back piece of mind after you've read this post.
Well, I don't think you are nuts, but I doubt your conclusions.
Skegs don't just fall off from going 80 mph. There are thousands of boats out there that go faster than that, and the skegs are still intact.
The skeg is a prop protector.
It is not a rudder.
If the skeg is not there, it will not cause the boat to veer or turn.
Most importantly, if the boat was never recovered, how can you make the assumption that the skeg broke off, and that it caused the accident?
The boat won't turn if the motor doesn't turn.
If the accident happened as you say, I would guess the steering failed.
