how important are watertubes?
Rldsl
How important are those little plastic water guide tubes that for from the meal lines to the water pump housing ( 74 Johnson v-4 135hp)par nos are 314681 for the short and 314775 for the long.they appear to jus help line up the tubes on the rubber grommets, if this is the case can it be done without or by rigging something similar? Thanks
Honorary Supreme Mariner
The only purpose is to guide the copper tubes into the water pump.---Make up whatever you can using hose ./ plastic plumbing fittings drilled out / etc , etc.
Rldsl
Thanks, the original ones had been misplaced but while eyeballing every chunk of scrap around, they resurfaced thankfully. This is good to know though as they likely will not survive until the next pump job
