How hot is it supposed to get?
Mdraper530
Yesterday I went to the lake to run my boat. Seemed to be running okay. When I felt the block it was kinda warm. I could hold my finger there for about 30 secs. After that i touched the cylinder head and was not that warm. I have a 1964 johnson 75 hp. My question would be. Is the engine block going to get hotter than the cylinder head? If my temp light was working right it would trigger off of the cylinder head? meaning the engine block would be hotter than when I was touching it. Thanks.
bktheking
Re: How hot is it supposed to get?
Doesn't sound like it's running hot, if they run hot they melt paint, if you could hold your hand there for 30 seconds you are fine.
Solittle
If you plan on fussin with boats for a long time get you a infa red temp gun for your tool box.
Most OMC engines are designed to run around 140 deg +/-.
