how fast ?
ryan 98
Here it goes. I'm not really sure if this is a great idea or a really bad one. the boat looks to be in disrepair but i'm really just cutting a few rotten spots out of it and reinforcing it along the way, the transom and structure are still very strong. with a 9.5 and a factory prop i was seeing about 25 mph on the GPS which is accurate, but it wasn't fast enough. so i found this 1960 18 hp johnson which runs like a top (i was actually a bit disappointed when i bought it and it was running, no fun for me) and i plan to run it on this boat. how fast do you think i could expect to see? i weigh about 160 then its just boat and engine from there on. also any ideas on a steering setup would be great. i used a straight bar on the back of the 9.5 but i don't think that will work here. there isn't enough space at the front for a conventional setup since the boat is so narrow.
ryan 98
No Title
Finally. i kept getting an empty response message when i tried to add photos and i couldn't edit the original post due to some server error.
lckstckn2smknbrls
I don't know about speed but I have a 10' hydro that is a long term project, I'm planning on using a rotary steering set up.
My plan is to mount the rotary unit upside down and use a long cable that comes off the left side of the unit, circling around in the bow and down the right side of the boat to the motor.
Watermann
No way to know, the pic didn't come through and no description of the boat other than it's part rotten and some solid.
ryan 98
this forum is keeps breaking on me for some reason. the teleflex steering warped around the front was the same idea i originally had. unfortunately to meet the motor at the right angle it had to stick like 2 feet out from the side so i went with cable steering.
