Re: How Fast ?
If you should find the cable to long, this may be what happened as you say the cables are new. In the control box, when you run the core wire into into the plastic sleeve with the brass connector, the wire must pass thru the connector, and be flush with the outer plastic sleeve, in other word's, it has to be clear thru, but flush, not sticking out at all. When you tighten the two pinch bolts, back both out until loose. Then tighten one screw until it makes contact with the core wire, then give it one complete turn. This puts the proper kink in the wire, then tighten the other screw. Do this at both end's of the cable. At the engine, is the shift lever straight up, and down in neatrul. Straight up, and down is really not the proper adjustment, I just want to know if it has been worked with.
