FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Use a prop calculator to calculate theoretical speed and the speed you could achieve at xx% slip. You should be able to get in the 10-15% slip range with it dialed in right. That will give you the best idea.
Already gave you my opinion on the prop forum. You might also have a waterlogged foam problem if the previous owner left it out uncovered in the rain alot or it sat tied up to a dock. My 16 foot Lund pike had over 200# of water logged foam under the floor when I replaced the plywood/carpet this winter!!!
i dont know but i'm going to find out i just purchased a 79 lund fiberglass 15 1/2 ft with dt 115 i'll let you know how fast it is i still dont know what model this boat is
Sounds like an indash speedo or pedal wheel fishfinder speed to me. Really high performance bass boats take some work to get those speeds with a 115. A rivited hull aluminum boat is never going reach 52mph on GPS with a 115 unless you pull the whole interior out and run around with a close to bare hull, Even a welded hull aluminum wouldn't reach those speeds due to the design limitations of aluminum. My boat for example has had 3 different pedal wheels and one pilot tube indash speedo in it since it was new, All 4 read quite a bit higher than GPS speed with the pilot tube being the worst. With a 130 yamaha on the back (boat rated for a 75) it showed 58mph on the dash, and 55mph on the fishfinder. Actual speed was 52mph gps. With a 70hp 4 stroke I see 45mph on the dash, 42 on the fishfinder and 38mph GPS speed. The dash and fishfinder speedos are now removed from my boat and I have new fishfinder with built in GPS for speed.
Not too far off the chart, my 17' Angler SS speedo is dead on with my GPS. 30.4 mph with a Susuki 115 4-stroke, all of the 32 gal of fuel, and 2 people. But I'm so way under propped (13.5 x 15)! Hope to have that rectified within a month or two.
As Mike (Esox) stated, I don't think there are that many Lund owners around here. Best case may be to get a response for something close in weight. Unfortunately I'm not overly familiar with all the different Lund models and what they weight but only believe my 17' Angler SS is a heavy boat.
I saw you have a post up in the Prop Forum. That is likely your best bet for answers with this issue. I tried here with prop questions at one time hoping to hear from another with a very similar setup but pretty much struck out as you are now.
After reading for a while, I'm getting the impression you want the motor as high on the transom as you can get to reduce the uneccessary drag from the lower unit. But I have no actual experience with this specific topic to assist any further than what I've gleened from the Prop Forum information of just keeping the ventilation plate at the water line when running and just low enough to prevent excessive ventilation problems.
Go to Lund's website and get their 1-800#. Call and ask for Engineering. They have test data on tons of boat and motor combinations. They can give you a much better idea on what your boat could be running.
Not sure what motor mfr you have Marty but that's an idea. I called Lund but they said they have no info/suggestion for a Johnson motor on the Angler SS. Well... no other suggestion than get some different props and try them, which is the same stated on this site.
Most of the major engine manufacters have test data on their websites also. I don't know how old your boat is but most of the 115's on 17's are about 40-43 mph.
The sky is the limit with the after market props. Most likely only a couple will work well your particular rig. It took 2 props and raising the motor a hole at a time to get the best performance out of mine. A lot of time and testing different setups went into that.
