how fast with a 115 2 stroke?
Tcrum5711
Re: how fast with a 115 2 stroke?
On the bracket that holds on your motor, there should be four bolts through your transom that holds the motor on. The two top ones should have holes that they go through. The two bottom ones should have some oval looking holes that they slide through. The holes at the top are the holes that I'm talking about. That's your height adjustment for your motor. You take out the top bolts and LOOSEN the bottom ones to move the motor up and down without having to take the motor off the back of the boat. It kinda slides up and down when you use a garage jack under the skeg.
marty f
do you need to seal it after you move it?
