how far can cylinder head be milled
One of the cylinder heads is dinged up on my 82, 2 stroke,70 hp evinrude mod#e70elcnb. How far can it be milled down without causing an issue
If the head is all pitted and damaged you need to determine the cause.-------Either the motor was apart before or it needs to come apart now.----You say there is no compression ??
Motor is apart now. Part off the piston ring broke off and chewed up the head. Cylinder it ok. I am replacing the piston
Chrisravosa36
parts are pretty easy to find with .20 o.s but I belive they have some .30 o.s parts to. only go to .20 if you can, it would be cheaper and if a problem did occur again you can (simply) change to .30. Pictures always help!
jimmbo
It is very rare for a Piston Ring to break and not damage the cylinder. As for milling the cylinder head, if the ring put a bunch of pits and marks on it, milling is not going to clean it up.
Faztbullet
You can mill .030 off head and any remaining indentations will fill in with carbon,,,wont hurt a thing. Just make sure there is no metal remnants of the ring embedded.
