- May 16, 2009
- 9,271
How do you do it?
1. Do you Just drain the water out only.
2. Do you drain the water out first By taking off hoses and drain plugs around the engine, Then fill the engine with Anti-freeze with one of the hoses removed inside the boat, Then start the engine till it comes out the Exhaust.
3. Do you leave the water in the engine, Then use the muffs to fill with anti-Freeze till it comes out the exhaust.
4. Do you drain the engine first, Then fill with Anti-Freeze using the muffs.
5. I do not drain or treat the engine at all, But should Because of where I live.
6. I do not need to Drain or Treat or Winterize the engine, Because I normaly will use the boat over the winter time, Because of where I live.
7. I store the boat inside where it's warm, And don't need to treat the engine like this at all.
8. Other.
Also here is another thread I made with a poll on storing the fuel over the winter In the link below, Just in case you would like to see how it came out also.
http://forums.iboats.com/showthread.php?t=358698
8. Other.
