Re: How do you set breaker points on 35 hp engine?
ShaunR, I d/n mean any harm being short but that was the best I could do then. Plus, your question is leading me to believe you need to read about the needs then ask specific questions.
1. Your local Library could be a source for an O/B repair manual.
2. Your points might not need adjusting/setting vs cleaning and adjusting if needed.
3. What year is your 35 hp Chrysler? Are you sure you have points?
4. I have a 1970 35 hp Chrysler, the points probably h/n been changed/set but once since 1985 but cleaned and checked the gap when sluggish etc.
5. A spark tester used with the plugs out has been my most accurate tester vs plugs that will test also.
6. I would like to know from the Pros why the tester will easily show a spark when a plug?s hard to see?
7. I attached the type of tester I use but I?m sure there are others at your auto store and etc just as good.
Good Luck! And please reply back . JOW
