How do you repair a skeg on a composite volvo-penta outdrive?
alakanotariver
I have a volvo-penta composite outdrive and the skeg is completely broken off, is there any way to repair or do I need to replace the whole outdrive?
jerryjerry05
Re: How do you repair a skeg on a composite volvo-penta outdrive?
I'd contact a Volvo dealer.Cobe Marine in Pasadena Md.410) 255-9488
This guy has been a great help.J
robjen1019
Ive had good luck with this product with damaged skegs
http://www.blackfinskeg.com/home/
I put one on my dp last year. It hasn't come off. It just glues on. The glue is a rubber that basically acts like a bumper for your lower unit. I'm sure it is alot cheaper than a replacement, and if you hit something again, It will probably just break of again, and not take the rest of the lower unit like a bolted on replacement.
Don S
You have the Volvo XDP outdrive, none of the above links cover that outdrive. I don't know of any products to replace it.
Ayuh,... So what are they actually made of Don,..?? have you seen 1 yet,..??
If it's of most any of the composite housing stuff I've seen,...
It's reasonably concievable that it can be repaired with an Epoxy...
Don S
It's the composite material over aluminum. The skeg is also a lot thicker than your normal Alpha, Volvo, or OMC skeg.
spdracr39
Although its probably not a great idea the skeg was broken at least 2/3 off my boat when I bought it and after running it a few times I can't even notice that its not there. I know it helps protect the prop and I am getting it welded back on this winter I'm just sayin you could run without it over spending a gazillion dollars fixing it.
tkrfxr
The drive's shell is made of vinyl ester composite, and can be repaired with fiberglass resin, like your boat's fiberglass....
Look at this old page for manufacturing details....
http://www.compositesworld.com/arti...-boat-stern-drive-resist-corrosion-and-damage
Replacing a whole skeg may take a professional job, but it should be doable.
